GILFILLAN 66AM 66DM
Sorry about posting the schematics that list it as L5. Their are three different sets of schematics. The parts listing That I have does not list a L5 or L8.
We are talking about the same part.
The coil between c18 B & C
I am very thankful for your help. I'm trying to find the part being sold. I'm not really set up to rewind a coil at this point.
GILFILLAN 66AM 66DM - by Bradley Rush - 05-24-2012, 03:05 AM
RE: GILFILLAN 66AM 66DM - by morzh - 05-24-2012, 09:26 AM
RE: GILFILLAN 66AM 66DM - by Arran - 05-24-2012, 09:03 PM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 05-28-2012, 03:52 PM
RE: GILFILLAN 66AM 66DM - by morzh - 05-28-2012, 07:55 PM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 05-29-2012, 01:29 AM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 05-31-2012, 02:03 PM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 06-03-2012, 05:24 AM
RE: GILFILLAN 66AM 66DM - by morzh - 06-03-2012, 11:07 AM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 06-03-2012, 11:07 PM
Philco 91 Tuning Condenser
There are currently 6972 online users. [Complete List]
» 2 Member(s) | 6970 Guest(s)
