Emerson DB-296 Kicking My Rear End Hard!
For the last two days I've been trying to get an Emerson DB-296 that I bought last weekend at a swap meet. It didn't play when I purchased it. I've re-capped it, checked the resistors, checked the tubes, etc. etc. etc. I have audio, but little if any signal. I've aligned the IF cans, checked continuity on all coils.
I checked tube voltages and here's what I have:
TUBE = 12SA7
PLATE ACTUAL 95 = RIDERS SAYS IT SHOULD BE = 88
SCREEN ACTUAL 106 = RIDERS SAYS IT SHOULD BE = 88
CATHODE ACTUAL 0 = RIDERS SAYS IT SHOULD BE = 0
TUBE = 12K7 (NO PLATE OR SCREEN VOLTAGE)
PLATE ACTUAL 0 = RIDERS SAYS IT SHOULD BE = 88
SCREEN ACTUAL 0 = RIDERS SAYS IT SHOULD BE = 88
TUBE = 12SQ7 (REALLY HIGH ON THE CATHODE VOLTAGE)
PLATE ACTUAL 55 = RIDERS SAYS IT SHOULD BE = 30
SCREEN ACTUAL 1.5 = RIDERS SAYS IT SHOULD BE = 0
CATHODE ACTUAL 103 = RIDERS SAYS IT SHOULD BE = 0
TUBE = 50L6
PLATE ACTUAL 86 = RIDERS SHOULD BE = 82
SCREEN ACTUAL 5.4 = RIDERS SAYS IT SHOULD BE = 88
CATHODE ACTUAL 6.0 = RIDERS SAYS IT SHOULD BE = 5.6
Any suggestions would be greatly welcomed!
Emerson DB-296 Kicking My Rear End Hard! - by dnitram - 05-29-2012, 02:18 AM
There are currently 4540 online users. [Complete List]
» 1 Member(s) | 4539 Guest(s)
