replacing 38-116 code 125 RF deck capacitors
I think removing the tuning cap is earier than removing the RF deck now that I have seen some pictures of the deck removed. Less to take apart by far. All caps are easy to get to except that one (part 7). Next time I'll try to put it in from underneath instead of running the lead thorugh to hole on top. That way you never see it when completed.
RE: replacing 38-116 code 125 RF deck capacitors - by SteveJB - 05-29-2012, 04:56 PM
The speaker table error?
Philco 70 antenna lead
