Practical Battery Operation
Terry , Thanks for the info ! Just one more question if you get a chance.
How long do the 9 volt batteries last roughly ? These radios must not consume much power. I was hoping someone would say there were options that did not gang them together.But when you think about it I guess the options are pretty limited. Only so many voltages made.
From the sounds of it the heater batteries are delivering most of the current . Thanks again!
Bill T
Practical Battery Operation - by bill T - 02-12-2007, 10:41 AM
[No subject] - by Terry Judkins - 02-12-2007, 02:31 PM
[No subject] - by bill T - 02-12-2007, 08:41 PM
[No subject] - by Bill Hutchinson - 02-12-2007, 11:15 PM
[No subject] - by bill T - 02-13-2007, 07:20 AM
Battery's - by BILL - 02-15-2007, 12:17 PM
[No subject] - by bill T - 02-18-2007, 09:33 AM
There are currently 10544 online users. [Complete List]
» 4 Member(s) | 10540 Guest(s)
AvatarAvatarAvatarAvatar
