  • 1 Vote(s) - 5 Average
A Philco 16B followed me home.
My 16B tombstone (non-shouldered) has the same knobs on the three lower controls that is on the "fine" adjust portion of the dual drive control. From what I have seen, some had the "acorn" knobs on the three lower controls, while others had those like my set has.
RE: A Philco 16B followed me home. - by TA Forbes - 05-27-2012, 11:28 PM
RE: A Philco 16B followed me home. - by y2kbruce - 05-29-2012, 09:50 AM
RE: A Philco 16B followed me home. - by TA Forbes - 05-31-2012, 12:02 PM
RE: A Philco 16B followed me home. - by Art Hoch - 05-31-2012, 08:34 PM
RE: A Philco 16B followed me home. - by Art Hoch - 05-31-2012, 08:42 PM
Philco 91 Tuning Condenser
