Philco 42-RP1
Probably the cartridge. You can try another source of audio that is hi z. Did the 6A7 fix up your radio?
Philco 42-RP1 - by OldJack1969 - 05-31-2012, 03:02 PM
RE: Philco 42-RP1 - by Ron Ramirez - 05-31-2012, 06:37 PM
RE: Philco 42-RP1 - by OldJack1969 - 06-01-2012, 06:16 PM
RE: Philco 42-RP1 - by OldJack1969 - 06-01-2012, 06:17 PM
RE: Philco 42-RP1 - by 7estatdef - 06-01-2012, 07:27 PM
RE: Philco 38-12 dial lamp and 6A7 Tube - by 7estatdef - 05-31-2012, 03:22 PM
The speaker table error?
Philco 70 antenna lead
