  • 1 Vote(s) - 1 Average
Growing up quick...with a 38-690xx Pics added.
I found some suitable material to reinforce the existing wafers. That "reformed" lytic has been straightened and restuffed. I managed to clean up the mangled shield bases and they will now accept shields correctly. Now all I have to do is locate two shields Icon_rolleyes
RE: Growing up quick...with a 38-690xx Pics added. - by badwaxcaps - 05-31-2012, 11:51 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
