Practical Battery Operation
I've made the battery packs for old radios with good results using dollar store battery's , about 10 years ago in the BIG ice storm in the north east I played my 1942 Zenith 7G605 Transocean Clipper 60 hours ,never failed
Practical Battery Operation - by bill T - 02-12-2007, 10:41 AM
[No subject] - by Terry Judkins - 02-12-2007, 02:31 PM
[No subject] - by bill T - 02-12-2007, 08:41 PM
[No subject] - by Bill Hutchinson - 02-12-2007, 11:15 PM
[No subject] - by bill T - 02-13-2007, 07:20 AM
Battery's - by BILL - 02-15-2007, 12:17 PM
[No subject] - by bill T - 02-18-2007, 09:33 AM
There are currently 5797 online users. [Complete List]
» 4 Member(s) | 5793 Guest(s)
AvatarAvatarAvatarAvatar
