Cap Question
you can find by googleing for "capacitor value and conversion chart" on the one you listed it is 1st#, 2nd#, then how many zeros- 22000 pf. just remember those are listed in picofarad you can find the chart for converting to microfarad by looking for what I listed above.
Cap Question - by 7estatdef - 06-01-2012, 05:46 PM
RE: Cap Question - by tab10672 - 06-01-2012, 06:33 PM
RE: Cap Question - by morzh - 06-01-2012, 07:51 PM
RE: Cap Question - by Eric T - 06-05-2012, 08:34 PM
RE: Cap Question - by TimC - 06-05-2012, 10:18 PM
RE: Cap Question - by 7estatdef - 06-07-2012, 09:25 PM
The speaker table error?
Philco 70 antenna lead
