Bakelite Block Question
That's ODG ("oh-dee-gee"), and yes, same configuration. The 'O' simply means that this "universal style" block used hi-temp wax impregnation. See page 2-3 in "Philco Condensers and More," 2nd. edition by Ray Bintliff. Info on my bakelite block condenser page.
Bakelite Block Question - by n9vu - 02-18-2007, 12:33 AM
[No subject] - by Chuck Schwark - 02-18-2007, 11:47 AM
[No subject] - by n9vu - 02-18-2007, 12:02 PM
There are currently 10505 online users. [Complete List]
» 2 Member(s) | 10503 Guest(s)
