  • 1 Vote(s) - 5 Average
New Project16B Cathedral
Hi Guys,
I use the same method as Jerry. Break the thin wires with the drill bit on the rivets, flip the block over, then I use a small embossing (heat) gun. The small tip with concentrated heat is great to heat up the blocks and not the other parts of the set.
[Image: http://www.stamp-happy.com/images/EP0046.gif]
You can get them at JoAnns or craft stores for under $20.
They (blocks) usually get soft enough to push right out with no mess.
Very rarely though, I will run across a block where the tar is a lot harder than the rest. Almost crumbly when warmed a bit. Maybe a harder batch of tar that day? Those you will have to sometimes pick out with a small tool.
New Project16B Cathedral - by LedHed - 04-26-2012, 09:53 AM
RE: New Project16B Cathedral - by TA Forbes - 04-26-2012, 12:53 PM
RE: New Project16B Cathedral - by Chuck Schwark - 04-26-2012, 01:34 PM
RE: New Project16B Cathedral - by LedHed - 04-26-2012, 03:09 PM
RE: New Project16B Cathedral - by codefox1 - 04-26-2012, 04:18 PM
RE: New Project16B Cathedral - by TA Forbes - 04-26-2012, 07:09 PM
RE: New Project16B Cathedral - by Glenn Roberts - 04-27-2012, 04:13 AM
RE: New Project16B Cathedral - by Chuck Schwark - 04-27-2012, 10:03 AM
RE: New Project16B Cathedral - by Art Hoch - 05-31-2012, 08:47 PM
RE: New Project16B Cathedral - by TA Forbes - 05-31-2012, 11:41 PM
RE: New Project16B Cathedral - by jerryhawthorne - 06-03-2012, 10:44 PM
RE: New Project16B Cathedral - by codefox1 - 06-04-2012, 01:44 PM
RE: New Project16B Cathedral - by gary rabbitt - 06-05-2012, 12:38 AM
RE: New Project16B Cathedral - by jerryhawthorne - 06-21-2012, 02:33 AM
RE: New Project16B Cathedral - by AI2V - 06-21-2012, 09:32 AM
RE: New Project16B Cathedral - by TA Forbes - 06-21-2012, 12:36 PM
Philco 91 Tuning Condenser
There are currently 5757 online users. [Complete List]
» 4 Member(s) | 5753 Guest(s)
AvatarAvatarAvatarAvatar
