Zenith 9-S-262 Cabinet Issues - Need Recommendations
I don't know for sure, but the veneer may be mahogony.
As for an alternative method of patching, wood putty may work, but it will be very difficult to match the grain & will likely stand out like a sore thumb. Since it's a curved surface on the front / top, I think putty would be likely to crack or flake off. I think a veneer patch would be your best bet.
The gap on the top is probably due to expansion & contraction of the wood. Since it's not loose, maybe just screw in a couple of braces to the inside of the cabinet to prevent further separtation, and fill the gap on the outside with wood putty. It doesn't look like a big gap, so it shouldn't be too hard to match the color with a little stain.
Dave
RE: Zenith 9-S-262 Cabinet Issues - Need Recommendations - by Dave - 06-06-2012, 03:48 PM
Philco 91 Tuning Condenser
There are currently 8813 online users. [Complete List]
» 3 Member(s) | 8810 Guest(s)
