Mon UGLY 9s262
#53
I second what codefox1 recommended. I've seen guys use artists oil paints to blend in the color and then fine tip pens or markers to draw in the grain. With a little trial and error I bet you can make those spots blend in pretty well.
Mon UGLY 9s262 - by Gene Pederson - 05-05-2012, 10:26 PM
RE: Mon UGLY 9s262 - by Eliot Ness - 05-05-2012, 11:06 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-05-2012, 11:17 PM
RE: Mon UGLY 9s262 - by Arran - 05-06-2012, 12:19 AM
RE: Mon UGLY 9s262 - by Arran - 05-07-2012, 11:32 PM
RE: Mon UGLY 9s262 - by morzh - 05-05-2012, 11:30 PM
RE: Mon UGLY 9s262 - by Eliot Ness - 05-06-2012, 01:28 PM
RE: Mon UGLY 9s262 - by TA Forbes - 05-06-2012, 01:36 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-06-2012, 04:23 PM
RE: Mon UGLY 9s262 - by Eliot Ness - 05-06-2012, 05:07 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-06-2012, 05:52 PM
RE: Mon UGLY 9s262 - by Eliot Ness - 05-06-2012, 08:35 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-06-2012, 09:53 PM
RE: Mon UGLY 9s262 - by Eliot Ness - 05-07-2012, 11:34 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-06-2012, 11:15 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-08-2012, 08:20 PM
RE: Mon UGLY 9s262 - by Eliot Ness - 05-08-2012, 09:07 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-08-2012, 09:44 PM
RE: Mon UGLY 9s262 - by Arran - 05-08-2012, 11:30 PM
RE: Mon UGLY 9s262 - by codefox1 - 05-09-2012, 02:47 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-09-2012, 04:00 PM
RE: Mon UGLY 9s262 - by Arran - 05-09-2012, 07:37 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-20-2012, 11:02 AM
RE: Mon UGLY 9s262 - by Ron Ramirez - 05-20-2012, 01:14 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-20-2012, 02:42 PM
RE: Mon UGLY 9s262 - by morzh - 05-20-2012, 03:07 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-20-2012, 03:17 PM
RE: Mon UGLY 9s262 - by Ron Ramirez - 05-20-2012, 05:06 PM
RE: Mon UGLY 9s262 - by morzh - 05-20-2012, 08:39 PM
RE: Mon UGLY 9s262 - by morzh - 05-20-2012, 08:47 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-21-2012, 03:18 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-21-2012, 03:24 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-21-2012, 03:44 PM
RE: Mon UGLY 9s262 - by morzh - 05-21-2012, 04:57 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-21-2012, 05:57 PM
RE: Mon UGLY 9s262 - by Arran - 05-21-2012, 09:59 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-21-2012, 10:27 PM
RE: Mon UGLY 9s262 - by morzh - 05-21-2012, 11:00 PM
RE: Mon UGLY 9s262 - by Eliot Ness - 05-22-2012, 09:02 AM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-22-2012, 12:30 PM
RE: Mon UGLY 9s262 - by Geoff - 05-23-2012, 12:48 AM
RE: Mon UGLY 9s262 - by Arran - 05-23-2012, 02:07 AM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-23-2012, 07:27 AM
RE: Mon UGLY 9s262 - by Geoff - 05-23-2012, 06:09 PM
RE: Mon UGLY 9s262 - by Arran - 05-24-2012, 12:33 AM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-24-2012, 12:28 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 05-29-2012, 03:45 PM
RE: Mon UGLY 9s262 - by Arran - 05-29-2012, 11:42 PM
RE: Mon UGLY 9s262 - by morzh - 05-30-2012, 12:03 AM
RE: Mon UGLY 9s262 - by Arran - 05-30-2012, 09:06 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 06-03-2012, 10:55 PM
RE: Mon UGLY 9s262 - by codefox1 - 06-04-2012, 02:12 PM
RE: Mon UGLY 9s262 - by Eliot Ness - 06-06-2012, 08:15 PM
RE: Mon UGLY 9s262 - by Arran - 06-07-2012, 05:13 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 06-08-2012, 08:44 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 06-09-2012, 06:05 PM
RE: Mon UGLY 9s262 - by Ron Ramirez - 06-09-2012, 11:00 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 06-10-2012, 10:01 AM
RE: Mon UGLY 9s262 - by Ron Ramirez - 06-10-2012, 10:13 AM
RE: Mon UGLY 9s262 - by codefox1 - 06-10-2012, 10:40 AM
RE: Mon UGLY 9s262 - by morzh - 06-10-2012, 01:12 PM
RE: Mon UGLY 9s262 - by Eliot Ness - 06-11-2012, 10:18 AM
RE: Mon UGLY 9s262 - by Arran - 06-11-2012, 06:41 PM
RE: Mon UGLY 9s262 - by Gene Pederson - 09-10-2012, 08:05 PM
RE: Mon UGLY 9s262 - by Joe Rossi - 09-15-2012, 09:22 AM
Users browsing this thread: 15 Guest(s)
