42-340 filament circuit problem
Hey all,
I am working on a Philco 42-340 and everything was working great. Today I plugged it in and nothing happend. The transformer hummed, but the dial lights didn't light up. Also the 7Y4 tube was the only tube that has a lighted filament. I tested all of the tubes and they are good. If 7Y4 lights up then that tells me that the transformer is good. There isn't a broken circuit going to each of the filaments on the other tubes. I am at a loss. Any ideas?
42-340 filament circuit problem - by Guest - 02-22-2007, 09:58 AM
[No subject] - by Guest - 02-22-2007, 07:27 PM
There are currently 8479 online users. [Complete List]
» 1 Member(s) | 8478 Guest(s)
