38 116 low volume after recapp
Already stated that lack of proper bias on 6L6 will cause heavy load on power supply. The bias is set on pin 5 (control grid) and must be negative with respect to ground. Follow the volts! Triple check to see that power supply is wired correctly. Bias or negative circuits can be a little tricky and not so intuitive.
The driver transformer may or may not be bad.
I would also recommend you replace the small carbon resistors, as they are probably drifting up, and may do funny things under power that you can't test for.
38 116 low volume after recapp - by SteveJB - 06-07-2012, 03:03 PM
RE: 38 116 low volume after recapp - by rghines1 - 06-07-2012, 03:58 PM
RE: 38 116 low volume after recapp - by 7estatdef - 06-07-2012, 09:14 PM
RE: 38 116 low volume after recapp - by SteveJB - 06-07-2012, 09:42 PM
RE: 38 116 low volume after recapp - by 7estatdef - 06-08-2012, 06:54 AM
RE: 38 116 low volume after recapp - by SteveJB - 06-08-2012, 10:17 AM
RE: 38 116 low volume after recapp - by codefox1 - 06-08-2012, 11:09 AM
RE: 38 116 low volume after recapp - by SteveJB - 06-08-2012, 11:34 AM
RE: 38 116 low volume after recapp - by rghines1 - 06-08-2012, 04:41 PM
RE: 38 116 low volume after recapp - by SteveJB - 07-17-2012, 06:39 PM
The speaker table error?
Philco 70 antenna lead
