Threads: 55
City: Claremont, NH
The veneer prices ARE from Constantine's. Didn't find anything on the bay. As was suggested, I will go down to the paint store and see about getting some artists paint to see if I can match it that way.
Probably won't be until Monday as it is alumni weekend here. Claremont has the distinction of having the oldest active alumni association in the United States!
I have found a couple 262's on CL, but they are too far away and unless I can see some really good photos or else look at it in person, I won't be buying another one too soon.
Gene
(This post was last modified: 06-08-2012, 08:45 PM by Gene Pederson.)
Users browsing this thread: 15 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
