Nobody else wanted it...
At first thought the knobs are worth what I paid for the set. It was a 2 1/2 hr drive round trip + tolls. The sides are pretty good with some loose edges but all in all still tight. The center center section on the top is shot and the sub is a little loose. I think that piece is walnut and the sides are mahogany. Any way I should have some small pieces to fix that.
The chassis seem to be clean but missing 3 42 tubes and the 80.Speaker is shot but it has the older style with a screwed down cone so if all else is good and the spider is ok reconing is easy on this one. The output transformer has been replaced. Think I will be a fun project but don't know when I'll get to it...
ps Just got back from picking it up. He also had a Drake TR-22C I got too. (late 60's 2meter fm transceiver 1w out xtal controled)
Nobody else wanted it... - by 7estatdef - 06-11-2012, 12:35 PM
RE: Nobody else wanted it... - by gary rabbitt - 06-11-2012, 12:41 PM
RE: Nobody else wanted it... - by Arran - 06-11-2012, 06:03 PM
RE: Nobody else wanted it... - by 7estatdef - 06-11-2012, 08:30 PM
RE: Nobody else wanted it... - by Arran - 06-11-2012, 09:03 PM
RE: Nobody else wanted it... - by 7estatdef - 06-11-2012, 09:24 PM
RE: Nobody else wanted it... - by TA Forbes - 06-11-2012, 09:41 PM
RE: Nobody else wanted it... - by morzh - 06-11-2012, 10:31 PM
RE: Nobody else wanted it... - by 7estatdef - 06-11-2012, 10:53 PM
RE: Nobody else wanted it... - by Tom Hamilton - 06-12-2012, 01:42 PM
RE: Nobody else wanted it... - by Michael Gerber - 06-12-2012, 01:55 PM
RE: Nobody else wanted it... - by 7estatdef - 06-18-2012, 05:22 PM
RE: Nobody else wanted it... - by Chicago Jimmy - 06-18-2012, 07:32 PM
RE: Nobody else wanted it... - by 7estatdef - 07-26-2012, 01:21 AM
RE: Nobody else wanted it... - by codefox1 - 07-26-2012, 10:54 AM
Philco 91 Tuning Condenser
There are currently 5866 online users. [Complete List]
» 1 Member(s) | 5865 Guest(s)
