40-145 speaker hole
I always used something like a good quality of bond paper to patch holes in speakers, a tea bag may be good to re-enforce a tear after gluing but it's pretty thin to cover a hole. Also remember, do not use silicone inspite of what you may have heard, silicone is for the bathtub not speaker repair.
40-145 speaker hole - by Philcofan - 06-06-2012, 08:20 PM
RE: 40-145 speaker hole - by Dave - 06-07-2012, 11:25 AM
RE: 40-145 speaker hole - by Philcofan - 06-11-2012, 07:53 PM
RE: 40-145 speaker hole - by Arran - 06-11-2012, 09:41 PM
RE: 40-145 speaker hole - by 7estatdef - 06-11-2012, 09:47 PM
RE: 40-145 speaker hole - by codefox1 - 06-12-2012, 01:33 AM
RE: 40-145 speaker hole - by codefox1 - 06-12-2012, 01:34 AM
The speaker table error?
Philco 70 antenna lead
