40-145 speaker hole
Best is a little left over from the last time you bought a surround kit and didn't use it all up. I think it's similar to fabric glue, but I'm not a chemist. Reckon Somewhere between Elmer's and Rubber Cement.
40-145 speaker hole - by Philcofan - 06-06-2012, 08:20 PM
RE: 40-145 speaker hole - by Dave - 06-07-2012, 11:25 AM
RE: 40-145 speaker hole - by Philcofan - 06-11-2012, 07:53 PM
RE: 40-145 speaker hole - by Arran - 06-11-2012, 09:41 PM
RE: 40-145 speaker hole - by 7estatdef - 06-11-2012, 09:47 PM
RE: 40-145 speaker hole - by codefox1 - 06-12-2012, 01:33 AM
RE: 40-145 speaker hole - by codefox1 - 06-12-2012, 01:34 AM
The speaker table error?
Philco 70 antenna lead
