1935 Philco 630
The radio I bought in a garage sale has no grid cap wires going to the 6A7 tube and the 78 If tube should there be?
1935 Philco 630 - by Guest - 03-03-2007, 10:28 AM
[No subject] - by Chuck Schwark - 03-03-2007, 10:58 AM
There are currently 10280 online users. [Complete List]
» 2 Member(s) | 10278 Guest(s)
