A Zenith 10S669
I used to have one of these sets, but the faux finish was toast. Sounded rather good though when it was on. I finally traded it off a couple years later. Now I know where there is another, but haven't asked the guy about it yet.
A Zenith 10S669 - by 37silverstreak - 06-10-2012, 03:19 PM
RE: A Zenith 10S669 - by rocketeer - 06-13-2012, 11:05 AM
RE: A Zenith 10S669 - by Jayce - 06-13-2012, 11:09 AM
RE: A Zenith 10S669 - by Arran - 06-14-2012, 01:19 AM
RE: A Zenith 10S669 - by murf - 09-03-2012, 04:53 PM
RE: A Zenith 10S669 - by rocketeer - 09-03-2012, 06:17 PM
RE: A Zenith 10S669 - by murf - 09-03-2012, 07:33 PM
Philco 91 Tuning Condenser
There are currently 10040 online users. [Complete List]
» 2 Member(s) | 10038 Guest(s)
