WHICH 690 IS BEST BET?
The prices for the chassis and the cabinet resto seem high to me, but then again the 37/38-690 is a top of the line set.
I do not have either model, but I do have a 37-116 and a 38-116 and have to agree that the 38 is the better set.
WHICH 690 IS BEST BET? - by Sam samuelian - 06-13-2012, 07:31 AM
RE: WHICH 690 IS BEST BET? - by codefox1 - 06-13-2012, 02:01 PM
RE: WHICH 690 IS BEST BET? - by Ron Ramirez - 06-13-2012, 04:41 PM
RE: WHICH 690 IS BEST BET? - by Sam samuelian - 06-13-2012, 04:50 PM
RE: WHICH 690 IS BEST BET? - by TA Forbes - 06-13-2012, 09:32 PM
RE: WHICH 690 IS BEST BET? - by Arran - 06-14-2012, 12:57 AM
RE: WHICH 690 IS BEST BET? - by 7estatdef - 06-14-2012, 03:59 PM
RE: WHICH 690 IS BEST BET? - by Ron Ramirez - 06-14-2012, 08:45 PM
RE: WHICH 690 IS BEST BET? - by Arran - 06-14-2012, 09:41 PM
RE: WHICH 690 IS BEST BET? - by TA Forbes - 06-15-2012, 07:51 PM
RE: WHICH 690 IS BEST BET? - by Jayce - 06-15-2012, 08:00 PM
RE: WHICH 690 IS BEST BET? - by TA Forbes - 06-15-2012, 09:35 PM
RE: WHICH 690 IS BEST BET? - by Arran - 06-16-2012, 03:01 AM
RE: WHICH 690 IS BEST BET? - by Jayce - 06-16-2012, 03:44 PM
RE: WHICH 690 IS BEST BET? - by codefox1 - 06-16-2012, 11:41 PM
RE: WHICH 690 IS BEST BET? - by Sam samuelian - 06-19-2012, 01:09 PM
RE: WHICH 690 IS BEST BET? - by Ron Ramirez - 06-20-2012, 05:40 AM
RE: WHICH 690 IS BEST BET? - by Sam samuelian - 07-20-2012, 04:45 AM
RE: WHICH 690 IS BEST BET? - by PhilcoJohn - 07-20-2012, 07:10 PM
RE: WHICH 690 IS BEST BET? - by Ron Ramirez - 07-20-2012, 10:26 PM
RE: WHICH 690 IS BEST BET? - by Arran - 07-21-2012, 11:11 PM
RE: WHICH 690 IS BEST BET? - by Arran - 07-22-2012, 07:22 AM
RE: WHICH 690 IS BEST BET? - by Ron Ramirez - 07-22-2012, 08:14 AM
RE: WHICH 690 IS BEST BET? - by TA Forbes - 07-22-2012, 10:56 AM
RE: WHICH 690 IS BEST BET? - by Arran - 07-22-2012, 10:51 PM
Philco 91 Tuning Condenser
There are currently 5791 online users. [Complete List]
» 3 Member(s) | 5788 Guest(s)
