Just bought a Zenith Walton.
http://www.ebay.com/itm/ZENITH-12-S-232-...3f18954893
Are they really THIS sought after? Look at the bidding frenzy....and it is not even restored .
RE: Just bought a Zenith Walton. - by morzh - 06-08-2012, 07:12 PM
RE: Just bought a Zenith Walton. - by Eliot Ness - 06-12-2012, 05:19 PM
RE: Just bought a Zenith Walton. - by TA Forbes - 06-12-2012, 07:10 PM
RE: Just bought a Zenith Walton. - by Ron Ramirez - 06-12-2012, 08:33 PM
RE: Just bought a Zenith Walton. - by Eliot Ness - 06-13-2012, 12:13 AM
RE: Just bought a Zenith Walton. - by codefox1 - 06-13-2012, 03:49 AM
RE: Just bought a Zenith Walton. - by morzh - 06-13-2012, 09:42 PM
RE: Just bought a Zenith Walton. - by Arran - 06-14-2012, 01:45 AM
Philco 91 Tuning Condenser
There are currently 10499 online users. [Complete List]
» 1 Member(s) | 10498 Guest(s)
