Help with a Philco 48-482
Hello,
I am in the middle of restoring a Philco 48-482. I have recaped and replaced all of the out of tolerance resistors. Radio works great in AM and SW.
However the FM does not. I traced it down to the FM detector. L300 is open in the cathode circuit of the FM1000 tube. Is anyone familiar with this model, where you can tell me the value of the coil? I have the riders service info, but it doesn't show a value. Any help would be greatly appreciated.
Thanks
Dave
Help with a Philco 48-482 - by Guest - 03-06-2007, 09:59 PM
[No subject] - by Chuck Schwark - 03-06-2007, 10:26 PM
[No subject] - by Guest - 03-07-2007, 12:20 AM
