Philco 37-84 Photo Finish Help
I think I would strip this one and use a toned laquer. The loss is extensive.
From looks of it, structure is OK, but do see if anything needs to be reinforced or glued first. If there are any suppliers of fauz finish I am unaware of them, market would be pretty small, but someone here might be able to help.
If someone could come up with a decal solution in a few patterns, thier next vacation would be on us!
Philco 37-84 Photo Finish Help - by gpitt1960 - 06-16-2012, 01:04 PM
RE: Philco 37-84 Photo Finish Help - by codefox1 - 06-16-2012, 02:45 PM
RE: Philco 37-84 Photo Finish Help - by 7estatdef - 06-16-2012, 06:50 PM
RE: Philco 37-84 Photo Finish Help - by TA Forbes - 06-16-2012, 10:47 PM
RE: Philco 37-84 Photo Finish Help - by codefox1 - 06-17-2012, 03:21 AM
RE: Philco 37-84 Photo Finish Help - by gpitt1960 - 06-17-2012, 11:59 AM
RE: Philco 37-84 Photo Finish Help - by gpitt1960 - 06-17-2012, 12:21 PM
RE: Philco 37-84 Photo Finish Help - by 7estatdef - 06-17-2012, 02:12 PM
RE: Philco 37-84 Photo Finish Help - by codefox1 - 06-17-2012, 04:00 PM
RE: Philco 37-84 Photo Finish Help - by gpitt1960 - 06-17-2012, 08:56 PM
RE: Philco 37-84 Photo Finish Help - by gpitt1960 - 06-18-2012, 01:14 PM
RE: Philco 37-84 Photo Finish Help - by 7estatdef - 06-18-2012, 02:34 PM
RE: Philco 37-84 Photo Finish Help - by gpitt1960 - 06-26-2012, 07:45 PM
RE: Philco 37-84 Photo Finish Help - by 7estatdef - 06-26-2012, 10:03 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
There are currently 2024 online users. [Complete List]
» 3 Member(s) | 2021 Guest(s)
