40-150 issues
Well, it is not nesessarily an issue, depends.
Is it the original xfmr or a replacement?
If iot is a new replacement, it my be OK, as what truly matter is the impedance, and not just the DC resistance.
if however it os the original, there is a good chance you see the lowered DC resistance due to a large section short, then this may explain the overload. Again at this point it is a shot in the dark
40-150 issues - by RGallahue - 06-16-2012, 11:20 AM
RE: 40-150 issues - by morzh - 06-16-2012, 12:37 PM
RE: 40-150 issues - by RGallahue - 06-16-2012, 02:32 PM
RE: 40-150 issues - by morzh - 06-16-2012, 04:02 PM
RE: 40-150 issues - by RGallahue - 06-16-2012, 06:04 PM
RE: 40-150 issues - by 7estatdef - 06-16-2012, 06:34 PM
RE: 40-150 issues - by morzh - 06-16-2012, 07:53 PM
RE: 40-150 issues - by RGallahue - 06-16-2012, 08:15 PM
RE: 40-150 issues - by morzh - 06-16-2012, 08:31 PM
RE: 40-150 issues - by RGallahue - 06-16-2012, 09:34 PM
RE: 40-150 issues - by morzh - 06-16-2012, 11:05 PM
RE: 40-150 issues - by RGallahue - 06-17-2012, 10:38 AM
RE: 40-150 issues - by morzh - 06-17-2012, 11:27 AM
RE: 40-150 issues - by RGallahue - 06-17-2012, 11:46 AM
RE: 40-150 issues - by morzh - 06-17-2012, 01:47 PM
RE: 40-150 issues - by 7estatdef - 06-17-2012, 02:24 PM
RE: 40-150 issues - by RGallahue - 06-19-2012, 08:12 PM
RE: 40-150 issues - by morzh - 06-20-2012, 05:45 PM
RE: 40-150 issues - by RGallahue - 06-20-2012, 06:16 PM
RE: 40-150 issues - by morzh - 06-21-2012, 10:51 PM
RE: 40-150 issues - by morzh - 06-23-2012, 01:21 PM
The speaker table error?
Philco 70 antenna lead
