Nobody else wanted it...
I broke one of my rules and brought in inside to have a closer look. I did a bit of cleaning and bondoed the bottom where it was damaged. A friend tells me it's termites. Blew the dust off of the chassis, cleaned off the tubes and put a few drops of oil on the tuning drive. Cleaned up the dial it was really filthy but cleaned up great with a little OMS. See the problem is I've got this Packard set I need to get done but is one is MUCH more interesting to work on and a bit easier. I've got all the paper caps replaced on the Packard but need to do the filters and they are a bit of a pain, there in metal cans that are kinda hard to get to. Just need to get motivated to do it!!!
Nobody else wanted it... - by 7estatdef - 06-11-2012, 12:35 PM
RE: Nobody else wanted it... - by gary rabbitt - 06-11-2012, 12:41 PM
RE: Nobody else wanted it... - by Arran - 06-11-2012, 06:03 PM
RE: Nobody else wanted it... - by 7estatdef - 06-11-2012, 08:30 PM
RE: Nobody else wanted it... - by Arran - 06-11-2012, 09:03 PM
RE: Nobody else wanted it... - by 7estatdef - 06-11-2012, 09:24 PM
RE: Nobody else wanted it... - by TA Forbes - 06-11-2012, 09:41 PM
RE: Nobody else wanted it... - by morzh - 06-11-2012, 10:31 PM
RE: Nobody else wanted it... - by 7estatdef - 06-11-2012, 10:53 PM
RE: Nobody else wanted it... - by Tom Hamilton - 06-12-2012, 01:42 PM
RE: Nobody else wanted it... - by Michael Gerber - 06-12-2012, 01:55 PM
RE: Nobody else wanted it... - by 7estatdef - 06-18-2012, 05:22 PM
RE: Nobody else wanted it... - by Chicago Jimmy - 06-18-2012, 07:32 PM
RE: Nobody else wanted it... I was a bad boy!!! - by 7estatdef - 06-18-2012, 10:01 PM
RE: Nobody else wanted it... - by 7estatdef - 07-26-2012, 01:21 AM
RE: Nobody else wanted it... - by codefox1 - 07-26-2012, 10:54 AM
Philco 91 Tuning Condenser
There are currently 4106 online users. [Complete List]
» 1 Member(s) | 4105 Guest(s)
