Dimensions for a Philco
Very good! Icon_thumbup It always makes a positive difference when the wife approves of a radio, especially a console.
Dimensions for a Philco - by jerryhawthorne - 06-18-2012, 10:55 PM
RE: Dimensions for a Philco - by Ron Ramirez - 06-19-2012, 05:22 AM
RE: Dimensions for a Philco - by jerryhawthorne - 06-19-2012, 07:25 PM
RE: Dimensions for a Philco - by Ron Ramirez - 06-19-2012, 07:53 PM
RE: Dimensions for a Philco - by jerryhawthorne - 06-22-2012, 12:44 AM
RE: Dimensions for a Philco - by Arran - 06-22-2012, 02:10 AM
RE: Dimensions for a Philco - by jerryhawthorne - 06-22-2012, 03:02 PM
RE: Dimensions for a Philco - by Arran - 06-22-2012, 06:27 PM
RE: Dimensions for a Philco - by jerryhawthorne - 06-22-2012, 06:52 PM
RE: Dimensions for a Philco - by Arran - 06-22-2012, 07:18 PM
Philco 91 Tuning Condenser
There are currently 5999 online users. [Complete List]
» 2 Member(s) | 5997 Guest(s)
