custom built transformer question
Hmmm...I did not know Edcor did custom work. I have never purchased one of their transformers, but I have heard good things about them.
If they have already wound the transformer, it would be too late at this point to change the primary to 130V since the primary is usually the second winding from the inside - the high voltage secondary is usually the innermost winding. The filament windings are usually wound last.
This is not always true, but it seems to be the rule rather than the exception.
custom built transformer question - by raydog - 06-19-2012, 06:05 PM
RE: custom built transformer question - by raydog - 06-19-2012, 07:12 PM
RE: custom built transformer question - by Ron Ramirez - 06-19-2012, 07:57 PM
RE: custom built transformer question - by Arran - 06-19-2012, 08:45 PM
The speaker table error?
Philco 70 antenna lead
