custom built transformer question
Hammond is another good vendor who will custom wind transformers, but I don't think they rewind originals. Hammond costs more then Edcor apparently, but they under rate their transformers so if something is specified as having a 125 volt primary it will withstand 130 volts not to mention the current ratings are better then what they spec.
As for increasing the size of the primary it's too late for that, the only way around it if line voltage is a concern, is to add a bucking transformer in series with the primary. The voltage that you are getting from the high voltage side doesn't sound far off considering that there is no load.
custom built transformer question - by raydog - 06-19-2012, 06:05 PM
RE: custom built transformer question - by raydog - 06-19-2012, 07:12 PM
RE: custom built transformer question - by Arran - 06-19-2012, 08:45 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 8175 online users. [Complete List]
» 1 Member(s) | 8174 Guest(s)
