  • 1 Vote(s) - 5 Average
New Project16B Cathedral
Thanks Gary for the hint on the smaller heat gun. Will have to have the wife pick one of those up on her next (frequent) trips to Joannes. Like that better than my giant paint stripper heat gun that is not nearly as focused.
Jerry
New Project16B Cathedral - by LedHed - 04-26-2012, 09:53 AM
RE: New Project16B Cathedral - by TA Forbes - 04-26-2012, 12:53 PM
RE: New Project16B Cathedral - by Chuck Schwark - 04-26-2012, 01:34 PM
RE: New Project16B Cathedral - by LedHed - 04-26-2012, 03:09 PM
RE: New Project16B Cathedral - by codefox1 - 04-26-2012, 04:18 PM
RE: New Project16B Cathedral - by TA Forbes - 04-26-2012, 07:09 PM
RE: New Project16B Cathedral - by Glenn Roberts - 04-27-2012, 04:13 AM
RE: New Project16B Cathedral - by Chuck Schwark - 04-27-2012, 10:03 AM
RE: New Project16B Cathedral - by Art Hoch - 05-31-2012, 08:47 PM
RE: New Project16B Cathedral - by TA Forbes - 05-31-2012, 11:41 PM
RE: New Project16B Cathedral - by jerryhawthorne - 06-03-2012, 10:44 PM
RE: New Project16B Cathedral - by codefox1 - 06-04-2012, 01:44 PM
RE: New Project16B Cathedral - by gary rabbitt - 06-05-2012, 12:38 AM
RE: New Project16B Cathedral - by jerryhawthorne - 06-21-2012, 02:33 AM
RE: New Project16B Cathedral - by AI2V - 06-21-2012, 09:32 AM
RE: New Project16B Cathedral - by TA Forbes - 06-21-2012, 12:36 PM
Philco 91 Tuning Condenser
