Its the other way around, the radio calls for a 7AF7 but he had a 7N7. The specs are very similar on most points.
-Mars
46-1209 - by philco4me - 06-21-2012, 11:58 AM
RE: 46-1209 - by TA Forbes - 06-21-2012, 12:34 PM
RE: 46-1209 - by philco4me - 06-21-2012, 01:05 PM
RE: 46-1209 - by TA Forbes - 06-21-2012, 01:15 PM
RE: 46-1209 - by philco4me - 06-21-2012, 01:19 PM
RE: 46-1209 - by philco4me - 06-21-2012, 01:47 PM
RE: 46-1209 - by Marsupial - 06-21-2012, 01:49 PM
RE: 46-1209 - by philco4me - 06-21-2012, 02:08 PM
RE: 46-1209 - by philco4me - 06-21-2012, 04:58 PM
RE: 46-1209 - by Marsupial - 06-22-2012, 09:55 PM
RE: 46-1209 - by gary rabbitt - 06-22-2012, 11:50 PM
RE: 46-1209 - by codefox1 - 06-23-2012, 12:54 PM
RE: 46-1209 - by Marsupial - 06-23-2012, 03:58 PM
RE: 46-1209 - by D R FORD - 06-23-2012, 05:08 PM
RE: 46-1209 - by codefox1 - 06-23-2012, 05:32 PM
RE: 46-1209 - by philco4me - 06-25-2012, 01:01 PM
RE: 46-1209 - by philco4me - 07-02-2012, 10:20 AM
Philco 91 Tuning Condenser
There are currently 5932 online users. [Complete List]
» 2 Member(s) | 5930 Guest(s)
