I got another Rogers 10-12
Quote:Love the art deco cabinet design. First radio I've ever seen with a clock in it.
What's art deco about it?
I got another Rogers 10-12 - by Dan Walker - 06-20-2012, 07:11 PM
RE: I got another Rogers 10-12 - by PhilcoMike - 06-21-2012, 08:50 AM
RE: I got another Rogers 10-12 - by TA Forbes - 06-21-2012, 12:50 PM
RE: I got another Rogers 10-12 - by Glenn Roberts - 06-21-2012, 01:01 PM
RE: I got another Rogers 10-12 - by Ron Ramirez - 06-21-2012, 08:52 PM
RE: I got another Rogers 10-12 - by Dan Walker - 06-22-2012, 12:04 AM
RE: I got another Rogers 10-12 - by Jayce - 06-23-2012, 01:20 PM
RE: I got another Rogers 10-12 - by Arran - 06-23-2012, 08:11 PM
RE: I got another Rogers 10-12 - by Arran - 06-23-2012, 10:18 PM
RE: I got another Rogers 10-12 - by Dan Walker - 06-25-2012, 09:31 PM
RE: I got another Rogers 10-12 - by Arran - 06-26-2012, 06:31 PM
Philco 91 Tuning Condenser
There are currently 10200 online users. [Complete List]
» 2 Member(s) | 10198 Guest(s)
