I got another Rogers 10-12
Here's another possible culprit for the low volume, I see on the schematic that this set has a pair of audio interstage transformers, it isn't uncommon for the primary of one of those to open up. Check the plate voltage on the 6F6M driver tube, also check for plate voltage on the 86M 1st AF amp. With regard to the interstage between the 6F6M driver tube and the 86M 1st AF amp, there is also a 20,000 ohm resistor in series with the primary of the transformer so check that resistor as well as the continuity of the transformer.
I got another Rogers 10-12 - by Dan Walker - 06-20-2012, 07:11 PM
RE: I got another Rogers 10-12 - by PhilcoMike - 06-21-2012, 08:50 AM
RE: I got another Rogers 10-12 - by TA Forbes - 06-21-2012, 12:50 PM
RE: I got another Rogers 10-12 - by Glenn Roberts - 06-21-2012, 01:01 PM
RE: I got another Rogers 10-12 - by Ron Ramirez - 06-21-2012, 08:52 PM
RE: I got another Rogers 10-12 - by Dan Walker - 06-22-2012, 12:04 AM
RE: I got another Rogers 10-12 - by Jayce - 06-23-2012, 01:20 PM
RE: I got another Rogers 10-12 - by Arran - 06-23-2012, 08:11 PM
RE: I got another Rogers 10-12 - by Arran - 06-23-2012, 10:18 PM
RE: I got another Rogers 10-12 - by Dan Walker - 06-25-2012, 09:31 PM
RE: I got another Rogers 10-12 - by Arran - 06-26-2012, 06:31 PM
Eico 232 VTVM Schematic
There are currently 8784 online users. [Complete List]
» 2 Member(s) | 8782 Guest(s)
