  • 1 Vote(s) - 5 Average
Zenith 9-S-262 Restoration Chronicles
[Image: http://antiqueradios.com/gallery/main.ph...alNumber=2]
Here is the crusty band switch in need of some serious cleaning...
Band switch disassembled...
After lots of cleaning and polishing followed by clear acrylic spray on the silver pieces...
The mechanism for the motorized tuning. Again, very filthy...
Zenith 9-S-262 Restoration Chronicles - by Geoff - 06-28-2012, 12:56 AM
RE: Zenith 9-S-262 Restoration Chronicles - by Geoff - 06-28-2012, 12:57 AM
Users browsing this thread: 15 Guest(s)
There are currently 3488 online users. [Complete List]
» 1 Member(s) | 3487 Guest(s)
