More Bass Please!
Depends on what type of cartridge was originally there. I can recall having adaptors to use ceramic cartridge output to preamps designed for magnetic cartridges, but that was a long time ago. Probably some info on web or here on how to do that. I trust the bass is OK on AM.
More Bass Please! - by Harry - 06-28-2012, 05:15 PM
RE: More Bass Please! - by codefox1 - 06-28-2012, 06:08 PM
RE: More Bass Please! - by w4rtc - 06-28-2012, 06:33 PM
RE: More Bass Please! - by Harry - 06-28-2012, 07:28 PM
RE: More Bass Please! - by Ron Ramirez - 06-28-2012, 08:42 PM
RE: More Bass Please! - by Harry - 06-28-2012, 08:57 PM
RE: More Bass Please! - by w4rtc - 06-28-2012, 09:54 PM
RE: More Bass Please! - by Harry - 06-29-2012, 08:29 AM
RE: More Bass Please! - by PhilcoMike - 06-29-2012, 11:44 AM
RE: More Bass Please! - by w4rtc - 06-29-2012, 12:54 PM
RE: More Bass Please! - by Jayce - 06-29-2012, 06:05 PM
RE: More Bass Please! - by Harry - 06-29-2012, 10:46 PM
RE: More Bass Please! - by Jayce - 07-02-2012, 11:09 PM
RE: More Bass Please! - by Ron Ramirez - 07-03-2012, 05:27 AM
RE: More Bass Please! - by Harry - 07-03-2012, 07:44 AM
RE: More Bass Please! - by y2kbruce - 07-03-2012, 08:07 AM
RE: More Bass Please! - by Harry - 07-03-2012, 07:18 PM
RE: More Bass Please! - by Ron Ramirez - 07-03-2012, 07:21 PM
RE: More Bass Please! - by Harry - 07-03-2012, 09:08 PM
RE: More Bass Please! - by Jayce - 07-03-2012, 11:02 PM
RE: More Bass Please! - by Arran - 07-04-2012, 12:12 AM
RE: More Bass Please! - by Harry - 07-04-2012, 08:16 AM
Philco 91 Tuning Condenser
There are currently 10511 online users. [Complete List]
» 2 Member(s) | 10509 Guest(s)
