More Bass Please!
The bass seems to be same whether AM or phono. It also has shortwave, but that is really no good for bass anyway. Not sure what original cartridge was, but not magnetic, as there is no additional preamp stage built in to this receiver/preamp chassis. And, I would like to keep this as original as possible, but with MORE bass!
More Bass Please! - by Harry - 06-28-2012, 05:15 PM
RE: More Bass Please! - by codefox1 - 06-28-2012, 06:08 PM
RE: More Bass Please! - by w4rtc - 06-28-2012, 06:33 PM
RE: More Bass Please! - by Harry - 06-28-2012, 07:28 PM
RE: More Bass Please! - by Ron Ramirez - 06-28-2012, 08:42 PM
RE: More Bass Please! - by Harry - 06-28-2012, 08:57 PM
RE: More Bass Please! - by w4rtc - 06-28-2012, 09:54 PM
RE: More Bass Please! - by Harry - 06-29-2012, 08:29 AM
RE: More Bass Please! - by PhilcoMike - 06-29-2012, 11:44 AM
RE: More Bass Please! - by w4rtc - 06-29-2012, 12:54 PM
RE: More Bass Please! - by Jayce - 06-29-2012, 06:05 PM
RE: More Bass Please! - by Harry - 06-29-2012, 10:46 PM
RE: More Bass Please! - by Jayce - 07-02-2012, 11:09 PM
RE: More Bass Please! - by Ron Ramirez - 07-03-2012, 05:27 AM
RE: More Bass Please! - by Harry - 07-03-2012, 07:44 AM
RE: More Bass Please! - by y2kbruce - 07-03-2012, 08:07 AM
RE: More Bass Please! - by Harry - 07-03-2012, 07:18 PM
RE: More Bass Please! - by Ron Ramirez - 07-03-2012, 07:21 PM
RE: More Bass Please! - by Harry - 07-03-2012, 09:08 PM
RE: More Bass Please! - by Jayce - 07-03-2012, 11:02 PM
RE: More Bass Please! - by Arran - 07-04-2012, 12:12 AM
RE: More Bass Please! - by Harry - 07-04-2012, 08:16 AM
Philco 91 Tuning Condenser
There are currently 10111 online users. [Complete List]
» 3 Member(s) | 10108 Guest(s)
