More Bass Please!
Joe,
My Maggy is using a Webcor model "B" changer (I think). Not sure the arm you have would work or not. This Webcor arm has, at the back, two hex head screws that go thru two rubber isolation grommets into the top back of the arm. It comes off very easily, and is typical of the way most of the later arms were mounted. Maroon with a Webcor engraved style name plate. Thanks for your offer though. It is good to find so many helpful people on this site.
Harry. I may eventually get around to posting a couple of pics of this.
More Bass Please! - by Harry - 06-28-2012, 05:15 PM
RE: More Bass Please! - by codefox1 - 06-28-2012, 06:08 PM
RE: More Bass Please! - by w4rtc - 06-28-2012, 06:33 PM
RE: More Bass Please! - by Harry - 06-28-2012, 07:28 PM
RE: More Bass Please! - by Ron Ramirez - 06-28-2012, 08:42 PM
RE: More Bass Please! - by Harry - 06-28-2012, 08:57 PM
RE: More Bass Please! - by w4rtc - 06-28-2012, 09:54 PM
RE: More Bass Please! - by Harry - 06-29-2012, 08:29 AM
RE: More Bass Please! - by PhilcoMike - 06-29-2012, 11:44 AM
RE: More Bass Please! - by w4rtc - 06-29-2012, 12:54 PM
RE: More Bass Please! - by Jayce - 06-29-2012, 06:05 PM
RE: More Bass Please! - by Harry - 06-29-2012, 10:46 PM
RE: More Bass Please! - by Jayce - 07-02-2012, 11:09 PM
RE: More Bass Please! - by Ron Ramirez - 07-03-2012, 05:27 AM
RE: More Bass Please! - by Harry - 07-03-2012, 07:44 AM
RE: More Bass Please! - by y2kbruce - 07-03-2012, 08:07 AM
RE: More Bass Please! - by Harry - 07-03-2012, 07:18 PM
RE: More Bass Please! - by Ron Ramirez - 07-03-2012, 07:21 PM
RE: More Bass Please! - by Harry - 07-03-2012, 09:08 PM
RE: More Bass Please! - by Jayce - 07-03-2012, 11:02 PM
RE: More Bass Please! - by Arran - 07-04-2012, 12:12 AM
RE: More Bass Please! - by Harry - 07-04-2012, 08:16 AM
Philco 91 Tuning Condenser
There are currently 7239 online users. [Complete List]
» 2 Member(s) | 7237 Guest(s)
