My New Philco 15x
Bob, great to hear from you, I have been following your thread on the dx, and your youtube videos. I think our chassis are the same if I'm not mistaken. I will look over your chassis again and I cant wait to hear more about your dx restoration. I'm following that as a model for this one. Thanks for your help.
Also what type of light bulb fixture did you go with, on your shadow meter, and the bulb that sits above the speakers?
Thanks
My New Philco 15x - by Philco281989 - 06-28-2012, 04:54 PM
RE: My New Philco 15x - by Glenn Roberts - 06-28-2012, 06:06 PM
RE: My New Philco 15x - by Philco281989 - 06-28-2012, 06:24 PM
RE: My New Philco 15x - by Philco281989 - 06-28-2012, 06:44 PM
RE: My New Philco 15x - by 37silverstreak - 06-28-2012, 07:21 PM
RE: My New Philco 15x - by Philco281989 - 06-28-2012, 10:48 PM
RE: My New Philco 15x - by Bob Andersen - 06-29-2012, 12:24 AM
RE: My New Philco 15x - by Philco281989 - 06-29-2012, 08:49 AM
RE: My New Philco 15x - by Bob Andersen - 06-29-2012, 08:26 PM
RE: My New Philco 15x - by Philco281989 - 06-29-2012, 08:43 PM
RE: My New Philco 15x - by Arran - 06-29-2012, 09:08 PM
RE: My New Philco 15x - by Philco281989 - 06-29-2012, 09:48 PM
RE: My New Philco 15x - by Arran - 06-29-2012, 11:34 PM
RE: My New Philco 15x - by Bob Andersen - 06-30-2012, 07:33 PM
RE: My New Philco 15x - by CrumblingWires - 06-30-2012, 09:42 PM
RE: My New Philco 15x - by Philco281989 - 06-30-2012, 09:52 PM
RE: My New Philco 15x - by Bob Andersen - 07-01-2012, 02:50 PM
RE: My New Philco 15x - by Philco281989 - 07-01-2012, 03:43 PM
RE: My New Philco 15x - by Ron Ramirez - 07-11-2012, 04:19 PM
Philco 91 Tuning Condenser
