Silvertone Model 7048
Need somehelp with the pushbuttons. Finished with chasis and plays well but can not use the buttons. thsy will not move tuner and I am notsure if some mechanical parts are missing. I have the schematis(2) but they give no information of buttons. Any advise will be greatly appreciated.
Silvertone Model 7048 - by mickey1 - 06-29-2012, 09:01 AM
RE: Silvertone Model 7048 - by rghines1 - 06-29-2012, 11:02 AM
RE: Silvertone Model 7048 - by mickey1 - 07-01-2012, 05:46 AM
There are currently 5889 online users. [Complete List]
» 2 Member(s) | 5887 Guest(s)
