They finally arrived!
The two Philco's I purchased at Kutztown back in May finally got to AZ.
First is a 38-15. The set is in pretty good condition needs a lot of cleaning and appear to be untouched except for the added Radio/Phono adapter.
Pics:
[Image: http://i1129.photobucket.com/albums/m501...99f9c2.jpg]
[Image: http://i1129.photobucket.com/albums/m501...b873ff.jpg]
[Image: http://i1129.photobucket.com/albums/m501...8b3003.jpg]
[Image: http://i1129.photobucket.com/albums/m501...ed8660.jpg]
-Keith
They finally arrived! - by ipwizard - 06-30-2012, 03:58 PM
RE: They finally arrived! - by ipwizard - 06-30-2012, 04:02 PM
RE: They finally arrived! - by Michael Gerber - 06-30-2012, 05:18 PM
RE: They finally arrived! - by Paul Philco322 - 06-30-2012, 07:53 PM
RE: They finally arrived! - by TA Forbes - 07-02-2012, 04:58 PM
RE: They finally arrived! - by jerryhawthorne - 07-06-2012, 02:32 PM
Philco 91 Tuning Condenser
There are currently 5402 online users. [Complete List]
» 1 Member(s) | 5401 Guest(s)
