9S262 - getting started
#40
Well, today is the day of the first reward - the Zee played the local "Good oldies" station, and the sound was great.
And this is with the tone control still broken. - not even sure what it is set to.
After yesterday's recapping finished, I cleaned the tubes, which all had at least their filament intact and no obvious shorts, one of them, the second detector, said "bad" on its base, but I thought it is probably subpar but still working, at least for testing, as I still don't have a tube tester; soldered the grid cap to one of the tubes where it came off; put the rectifier in, made sure it rectified, then plugged the speaker, made sure the voltage is everywhere, plugged the rest of the tubes, saw them glow, then t oched the grid of the first stage and heard the hum. Connected a wire to Antenna, set the dial to the local station I usually listen to, and, voila, it played.
Well, I'm gonna finish the beer, then take the RF Gen. to it.
Now I have to:
- Find a new tone ctl switch
- Fix the tuning belt
- Fix the motordrive belt
- tune the IF and the dial
- The magic eye tube does not even glow green. Probably needs fixin'.
- check the SW foreign broadcast;
- Eventually test the tubes (well, just earned a little side money, enough to buy something nice, so, my love, take that!)
The audio transformer obviously is a successful choice, as it plays well and fit right in with minor adjustments.
This is it so far; will go to my main computer and post the photos of the recapped chassis.
9S262 - getting started - by morzh - 05-12-2012, 06:02 PM
RE: 9S262 - getting started - by morzh - 05-12-2012, 06:04 PM
RE: 9S262 - getting started - by Gene Pederson - 05-12-2012, 07:57 PM
RE: 9S262 - getting started - by morzh - 05-12-2012, 10:57 PM
RE: 9S262 - getting started - by morzh - 05-13-2012, 04:57 PM
RE: 9S262 - getting started - by codefox1 - 05-14-2012, 01:42 PM
RE: 9S262 - getting started - by morzh - 05-14-2012, 02:58 PM
RE: 9S262 - getting started - by Gene Pederson - 05-14-2012, 03:48 PM
RE: 9S262 - getting started - by Chuck Schwark - 05-14-2012, 04:53 PM
RE: 9S262 - getting started - by codefox1 - 05-14-2012, 04:55 PM
RE: 9S262 - getting started - by morzh - 05-14-2012, 06:19 PM
RE: 9S262 - getting started - by codefox1 - 05-14-2012, 07:31 PM
RE: 9S262 - getting started - by morzh - 05-14-2012, 11:26 PM
RE: 9S262 - getting started - by Arran - 05-15-2012, 10:36 PM
RE: 9S262 - getting started - by morzh - 05-16-2012, 09:53 AM
RE: 9S262 - getting started - by morzh - 05-19-2012, 09:46 PM
RE: 9S262 - getting started - by TA Forbes - 05-19-2012, 09:57 PM
RE: 9S262 - getting started - by morzh - 05-19-2012, 11:05 PM
RE: 9S262 - getting started - by morzh - 05-19-2012, 11:08 PM
RE: 9S262 - getting started - by Gene Pederson - 05-20-2012, 11:39 PM
RE: 9S262 - getting started - by morzh - 05-21-2012, 10:32 AM
RE: 9S262 - getting started - by rocketeer - 05-21-2012, 10:45 AM
RE: 9S262 - getting started - by morzh - 05-21-2012, 11:28 AM
RE: 9S262 - getting started - by rocketeer - 05-21-2012, 04:23 PM
RE: 9S262 - getting started - by morzh - 05-21-2012, 09:31 PM
RE: 9S262 - getting started - by Gene Pederson - 05-21-2012, 10:24 PM
RE: 9S262 - getting started - by morzh - 05-22-2012, 11:12 PM
RE: 9S262 - getting started - by morzh - 05-27-2012, 12:02 PM
RE: 9S262 - getting started - by morzh - 05-27-2012, 12:05 PM
RE: 9S262 - getting started - by morzh - 06-09-2012, 09:54 PM
RE: 9S262 - getting started - by TA Forbes - 06-10-2012, 02:14 PM
RE: 9S262 - getting started - by codefox1 - 06-10-2012, 03:22 PM
RE: 9S262 - getting started - by morzh - 06-10-2012, 04:30 PM
RE: 9S262 - getting started - by rocketeer - 06-13-2012, 10:39 AM
RE: 9S262 - getting started - by morzh - 06-15-2012, 09:57 PM
RE: 9S262 - getting started - by morzh - 06-15-2012, 10:09 PM
RE: 9S262 - getting started - by rocketeer - 06-16-2012, 08:28 AM
RE: 9S262 - getting started - by morzh - 06-16-2012, 10:59 AM
RE: 9S262 - getting started - by morzh - 06-29-2012, 12:32 AM
RE: 9S262 - getting started - by morzh - 06-30-2012, 04:51 PM
RE: 9S262 - getting started - by morzh - 06-30-2012, 05:09 PM
RE: 9S262 - getting started - by morzh - 06-30-2012, 11:02 PM
RE: 9S262 - getting started - by jth877 - 07-11-2012, 05:09 PM
RE: 9S262 - getting started - by morzh - 07-12-2012, 09:29 PM
RE: 9S262 - getting started - by morzh - 07-12-2012, 09:34 PM
RE: 9S262 - getting started - by jth877 - 07-13-2012, 12:48 PM
RE: 9S262 - getting started - by morzh - 07-13-2012, 07:29 PM
RE: 9S262 - getting started - by Arran - 07-13-2012, 09:00 PM
RE: 9S262 - getting started - by morzh - 07-14-2012, 11:39 AM
RE: 9S262 - getting started - by Arran - 07-14-2012, 08:34 PM
RE: 9S262 - getting started - by jth877 - 07-15-2012, 11:08 AM
RE: 9S262 - getting started - by morzh - 07-15-2012, 11:51 AM
RE: 9S262 - getting started - by jth877 - 07-15-2012, 08:38 PM
RE: 9S262 - getting started - by codefox1 - 07-15-2012, 11:35 PM
RE: 9S262 - getting started - by jth877 - 07-16-2012, 12:34 AM
RE: 9S262 - getting started - by codefox1 - 07-16-2012, 08:49 AM
RE: 9S262 - getting started - by morzh - 07-16-2012, 09:22 AM
RE: 9S262 - getting started - by jth877 - 07-16-2012, 10:30 AM
RE: 9S262 - getting started - by morzh - 07-16-2012, 07:43 PM
RE: 9S262 - getting started - by morzh - 07-16-2012, 07:50 PM
RE: 9S262 - getting started - by jth877 - 07-16-2012, 10:28 PM
RE: 9S262 - getting started - by morzh - 07-16-2012, 11:05 PM
RE: 9S262 - getting started - by jth877 - 07-17-2012, 09:40 AM
RE: 9S262 - getting started - by morzh - 07-17-2012, 08:10 PM
RE: 9S262 - getting started - by morzh - 07-17-2012, 08:11 PM
RE: 9S262 - getting started - by rocketeer - 07-17-2012, 09:20 PM
RE: 9S262 - getting started - by morzh - 07-17-2012, 11:34 PM
RE: 9S262 - getting started - by rocketeer - 07-18-2012, 02:08 PM
RE: 9S262 - getting started - by morzh - 07-18-2012, 08:48 PM
RE: 9S262 - getting started - by jth877 - 07-19-2012, 10:27 AM
RE: 9S262 - getting started - by morzh - 07-19-2012, 10:33 AM
RE: 9S262 - getting started - by rocketeer - 07-19-2012, 11:19 AM
RE: 9S262 - getting started - by morzh - 07-19-2012, 12:03 PM
RE: 9S262 - getting started - by jth877 - 07-19-2012, 01:35 PM
RE: 9S262 - getting started - by morzh - 07-19-2012, 02:34 PM
RE: 9S262 - getting started - by codefox1 - 07-19-2012, 07:39 PM
RE: 9S262 - getting started - by rocketeer - 07-19-2012, 08:21 PM
RE: 9S262 - getting started - by morzh - 07-19-2012, 08:39 PM
RE: 9S262 - getting started - by morzh - 07-22-2012, 11:10 AM
RE: 9S262 - getting started - by morzh - 09-01-2012, 05:00 PM
RE: 9S262 - getting started - by morzh - 09-03-2012, 11:47 AM
There are currently 5932 online users. [Complete List]
» 1 Member(s) | 5931 Guest(s)
