My tallest Philco console
Terry is right. It's either a 76 or 95.
76 - 7 tubes
95 - 9 tubes
If it is a 95 then the OP has a historically significant radio as the 95 was Philco's first radio to include automatic volume control (AVC).
My tallest Philco console - by DKinYORKpa - 07-01-2012, 04:57 PM
RE: My tallest Philco console - by Michael Gerber - 07-01-2012, 05:04 PM
RE: My tallest Philco console - by Philament - 07-01-2012, 06:31 PM
RE: My tallest Philco console - by Arran - 07-01-2012, 08:01 PM
RE: My tallest Philco console - by Ron Ramirez - 07-01-2012, 08:29 PM
RE: My tallest Philco console - by Philament - 07-01-2012, 08:57 PM
RE: My tallest Philco console - by Arran - 07-01-2012, 11:01 PM
RE: My tallest Philco console - by PhilcoMike - 07-02-2012, 11:32 AM
RE: My tallest Philco console - by GuyIncognito - 07-02-2012, 12:52 PM
RE: My tallest Philco console - by 7estatdef - 07-02-2012, 01:20 PM
RE: My tallest Philco console - by Ron Ramirez - 07-02-2012, 03:42 PM
RE: My tallest Philco console - by TA Forbes - 07-02-2012, 04:53 PM
RE: My tallest Philco console - by Arran - 07-02-2012, 05:36 PM
RE: My tallest Philco console - by Ron Ramirez - 07-02-2012, 06:27 PM
RE: My tallest Philco console - by DKinYORKpa - 07-02-2012, 07:45 PM
RE: My tallest Philco console - by Ron Ramirez - 07-02-2012, 08:05 PM
RE: My tallest Philco console - by Philament - 07-02-2012, 08:35 PM
RE: My tallest Philco console - by DKinYORKpa - 07-08-2012, 02:52 PM
RE: My tallest Philco console - by Ron Ramirez - 07-08-2012, 08:25 PM
Philco 91 Tuning Condenser
