Model 600 cabinet
The back of the cabinet is supposed to be fastened on to the rest of the cabinet, and the chassis is removed/installed from the bottom.
The back is a mirror image of the front, but there is no dial or holes for knobs, of course.
Model 600 cabinet - by Steve D - 07-02-2012, 04:36 PM
RE: Model 600 cabinet - by Ron Ramirez - 07-02-2012, 06:30 PM
RE: Model 600 cabinet - by 7estatdef - 07-02-2012, 11:06 PM
RE: Model 600 cabinet - by Steve D - 07-03-2012, 10:07 AM
RE: Model 600 cabinet - by Ron Ramirez - 07-03-2012, 10:20 AM
RE: Model 600 cabinet - by Arran - 07-03-2012, 09:29 PM
RE: Model 600 cabinet - by codefox1 - 07-04-2012, 11:33 AM
With these values I think you are OK; the Cmax for this tube is 40uF. Your Vbb could rise a bit, but probably not too m...morzh — 04:53 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
There are currently 1922 online users. [Complete List]
» 3 Member(s) | 1919 Guest(s)
