Finally - a 38-690!
Philament
20 watts in the 38-690. The 37-690 was advertised with 15 watts.
Finally - a 38-690! - by Ron Ramirez - 07-02-2012, 08:56 PM
RE: Finally - a 38-690! - by Chuck Schwark - 07-02-2012, 09:15 PM
RE: Finally - a 38-690! - by Philament - 07-02-2012, 09:45 PM
RE: Finally - a 38-690! - by Eliot Ness - 07-02-2012, 10:20 PM
RE: Finally - a 38-690! - by Glenn Roberts - 07-03-2012, 03:31 AM
RE: Finally - a 38-690! - by Ron Ramirez - 07-03-2012, 05:18 AM
RE: Finally - a 38-690! - by w4rtc - 07-03-2012, 08:40 AM
RE: Finally - a 38-690! - by DeckApe - 07-03-2012, 09:56 AM
RE: Finally - a 38-690! - by TA Forbes - 07-03-2012, 10:39 AM
RE: Finally - a 38-690! - by Bob Andersen - 07-03-2012, 04:34 PM
RE: Finally - a 38-690! - by Uffda - 07-03-2012, 05:25 PM
RE: Finally - a 38-690! - by Arran - 07-03-2012, 10:37 PM
RE: Finally - a 38-690! - by Tom Hamilton - 07-04-2012, 03:54 PM
RE: Finally - a 38-690! - by thirtiesradio - 09-11-2012, 11:12 PM
RE: Finally - a 38-690! - by Gene Pederson - 09-12-2012, 11:28 AM
RE: Finally - a 38-690! - by shaler78 - 09-12-2012, 06:54 PM
RE: Finally - a 38-690! - by Ron Ramirez - 09-12-2012, 06:59 PM
RE: Finally - a 38-690! - by Eliot Ness - 09-12-2012, 07:57 PM
RE: Finally - a 38-690! - by Ron Ramirez - 09-12-2012, 08:34 PM
RE: Finally - a 38-690! - by Rockola - 09-13-2012, 10:53 AM
Philco 91 Tuning Condenser
There are currently 3561 online users. [Complete List]
» 1 Member(s) | 3560 Guest(s)
