Model 600 cabinet
There is a variation of this method that Bob Andersen uses where he uses a head gun to heat up the underside of the veneer and the surface you are gluing it to, I tried the iron method to heat it directly and it dried out and split the veneer I was working with so I'm not a fan of it.
Model 600 cabinet - by Steve D - 07-02-2012, 04:36 PM
RE: Model 600 cabinet - by Ron Ramirez - 07-02-2012, 06:30 PM
RE: Model 600 cabinet - by 7estatdef - 07-02-2012, 11:06 PM
RE: Model 600 cabinet - by Steve D - 07-03-2012, 10:07 AM
RE: Model 600 cabinet - by Ron Ramirez - 07-03-2012, 10:20 AM
RE: Model 600 cabinet - by Arran - 07-03-2012, 09:29 PM
RE: Model 600 cabinet - by codefox1 - 07-04-2012, 11:33 AM
New member
Philco 630csx power cord
New member
There are currently 2600 online users. [Complete List]
» 4 Member(s) | 2596 Guest(s)
AvatarAvatarAvatarAvatar
