advice needed: restoring 47-1230 - FM & AM now works!!!! :D (uncertain about SW)
#39
How do I know if the SW section works? I seems to get only static on the SW band, and have no other SW radios to compare to. What should I be expecting?
I think this radio uses the same circuits for SW and AM. (let me know if I am wrong, won't be the first time)
-Mars
RE: advice needed: restoring 47-1230 - FM & AM now works!!!! :D (uncertain about SW) - by Marsupial - 07-05-2012, 10:34 PM
Philco 91 Tuning Condenser
There are currently 5804 online users. [Complete List]
» 3 Member(s) | 5801 Guest(s)
