advice needed: restoring 47-1230 - FM & AM now works!!!! :D (uncertain about SW)
#42
All the old carbon resistors have drifted up as a rule, or have become porous, some way out of tolerence. Best just replace them. Cheap enough. I normally do at same time as caps.
RE: advice needed: restoring 47-1230 - FM & AM now works!!!! :D (uncertain about SW) - by codefox1 - 07-06-2012, 04:25 AM
Philco 91 Tuning Condenser
There are currently 4356 online users. [Complete List]
» 1 Member(s) | 4355 Guest(s)
