Unknown AA5 set... any guesses?
CX serial number might be Climax, one of the many independent Chicago brands that isn't well documented.
Unknown AA5 set... any guesses? - by DeckApe - 07-05-2012, 07:44 PM
RE: Unknown AA5 set... any guesses? - by calmark - 07-05-2012, 09:03 PM
RE: Unknown AA5 set... any guesses? - by exray - 07-06-2012, 08:09 AM
RE: Unknown AA5 set... any guesses? - by DeckApe - 07-06-2012, 09:33 AM
Philco 91 Tuning Condenser
There are currently 10106 online users. [Complete List]
» 3 Member(s) | 10103 Guest(s)
