Unknown AA5 set... any guesses?
Very similar to the General (X)A5 series; only difference is the dial face. A brief look at the schematic looks like the right critter, too. Another contender is the 591. I just haven't found any with the same dial face.
I checked out Climax a little bit--boy, you're right, there isn't much out there. Radiomuseum.org didn't have any 5-tube schematics that the tube lineup matched. They had some pictures of cool cabinets, though Icon_smile
Unknown AA5 set... any guesses? - by DeckApe - 07-05-2012, 07:44 PM
RE: Unknown AA5 set... any guesses? - by calmark - 07-05-2012, 09:03 PM
RE: Unknown AA5 set... any guesses? - by exray - 07-06-2012, 08:09 AM
RE: Unknown AA5 set... any guesses? - by DeckApe - 07-06-2012, 09:33 AM
Philco 91 Tuning Condenser
There are currently 10393 online users. [Complete List]
» 2 Member(s) | 10391 Guest(s)
